:thumbup: Thanks on schooling me about transmissions. And god damn that car is dumb fast.mike93hatch;110451 wrote:i just tested a b16 oem diff and b16 obx lsd into the cg tranny and it works perfectly including the speedo.
thanks chris.
CG tranny onto d16z6 - everything you wanted to know
new discoveries..
my d16z6 block has all 3 TAPPED holes for the shaft.
the bolt pattern on a 94-01 teg intermediate shaft is is the exact same bolt pattern of the holes on my block.
BUT, if i used the 94-01 shaft all 3 holes on my block will be a 1/2" away from lining up with the holes on the shaft.
the CG intermediate shaft is the same length as the 94-01 but the mounting holes are a little closer to the tranny. so i guess ill need to use the CG shaft.. only one of its holes line up with the holes on my block and i think i could get away with drilling 2 new holes in the shaft mount to go into the holes on my block.
i measured everything tonight....blocks, trannies, axles, axle placement in the bay with the engine/tranny, etc and the integra driver side axle is only a 1/4" difference than my d-series axle so it will work. the pass side is just a little bit more different but we will just have to see once the tranny is bolted to teh engine in my car. im going to order the 90-93 integra axles from fidanza. ill make it all work.
also just ordered the howe pull type slave cylinder.. im staying hydro.. thanks transzex.
http://store.summitracing.com/partdetai ... toview=sku
and also went ahead and cut a tranny mount so it sits flush since the way ill be doing the mounts ill need it to sit flush to a plate of steel to weld. it will have the prothane inserts that i currently use but i also use a VERY hard aftermarket rear mount and front torque mounts.
the cg shaft is on the bottom and 94-01 shaft is on top in this pic.
anyone have pics of a ZC intermediate shaft?
found a pic of a 99-00 b16 intermediate shaft and it has a female end and the bolt pattern looks just like the 94-01 which lines right up on my block but is about a 1/2"off from the holes..
the holes in this b16 one looks like its about 1/2" closer to the tranny like i need.. what do you guys think??
b16
gsr and cg
anyone have measurements of a b16 shaft?
b16
gsr and cg
nevermind..... the b16 shaft is just longer and the mounting point is the same as the b18's.
but, does anyone have a zc shaft?
mmm parts are starting to show up...
zc intermediate shaft bolts right onto the z6 block with no modifications.. just need to find one.
cable to hydro conversion with no cables haha.
howe pull type slave cylinder about $50 shipped from summit.
im going to go get a shorter rod for the mount to shorten it up some and then weld a mount for this slave onto the transmission mount ill be making.
99PreludeSh
If there was rep points on this site you would have gotten atleast 10 from me.
BY FAR the most usefull thread on this site nice!
haha thanks. far from finished yet. most of the jibber jabber and details about this is are on d-series.org
ill probably break my current transmission tommorrow lol and then will start getting this thing in there. my lsd and axles are on the way and should be getting a ZC intermediate shaft today.
well i couldnt find any 5/16-24 threaded rods or bolts long enough to replace this one on the slave to make it shorter so i just got a 5/16-24 die and threaded the rest of the rod and cut it down.
much shorter. dont know why they made it so long..
ordered my fidanza axles and got this email from racingworks.com
oh and i always thought driveshaft shop made the fidanzas but now it is confirmed.
kinda wierd becuse driveshaft shops oem replacement axles cost as much as the fidanzas and the fidanzas are much stronger than oem.
oh and btw this is all going to happen real fast here real soon. just waiting on a few parts and it will be all finished with tons more pics.
i emailed him back and told him everything that is going on and what im doing to see what he thinks axle wise. ill have to wait on the fidanzas which ive been running for the past year and a half with tons of abuse and no problems..so i dont think ill go with the gator stage 1's. what do you think? the fidanzas are just $215 each.Hello Mike,
Fidanza’s next production run for axles is a couple weeks away still. We can place these axles on order for you and they will ship in a couple weeks.
If you need them sooner, we can have them ship directly through Drive Shaft Shop (the manufacturer for Fidanza Axles) But they will not be boxed with Fidanza Paperwork.
From the set up, it looks like you are ordering these for an ZC engine swap?
Fidanza Left Axle 90-93 Integra MT
Fidanza Right Axle 86-89 Integra MT
We also build Gator Racing Axles here, if you need something suited for Competition. They run 235 for Stage 1 (Street) or 359 for Stage 2 (Competition). These are actually built for your car, depending on use/ ride height / engine / horsepower rating, so they take about 2 days to complete before shipping.
Please confirm.
Racing Works
www.racingworks.com
10am-6pm Eastern Time Weekdays
