could be backed out rotor screw....
o2 heater code is a simple fix with a $1 radio shack resistor. (be sure to get the correct wattage and ohms)
help figure out whats wrong with my damn car
fixed. thanks for the help.
Racecore.com
Racecore.com
you care to elaborate on what was done to fix it so that if anyone comes across the same problem and they search they can find an answer.HardCore97;205057 wrote:fixed. thanks for the help.
it was throwing 4 codes, MAP, TPS, CYP, and o2 sensor heater. replaced the map with a different one i had in the garage, swapped my old dizzy back on to see if that fixed the CYP, plugged the o2 sensor up :facepalm: then reset the ecu and all is fine so far
Racecore.com
Racecore.com
