well it freakkin gets it
its a b16a with built head
vtec crack is just nuts
b16a problems
Miggyp17
b16a problems
i still cant get the damn tps sensor working right
i put a new one on and still cel
RIP - 91 HB d16z6 turbo - RIP 91 HB b16a
luvmyhondas
b16a problems
sounds like the dpfi to mpfi wiring is f'd up somewhere. you have to add a couple wires for injectors in that conversion, so check that area of your swap. both at the ecu and underhood....could be as simple as a broken wire/bad connection to injector #1.Miggyp17;139760 wrote:injector one the wiring was dead
now that it runs holy shit here come the tickets
wired injector 1 and 4 together and it just goes
Clayton
b16a problems
you did what?Miggyp17;139760 wrote:injector one the wiring was dead
Miggyp17
b16a problems
since injector 4 fires at the same time injector 1 does i spliced 1 onto 4
