I'm pretty sure it's a sticking solenoid, Mike. Low throttle, it will flare a little bit. If you get on it where the trans line pressure is up a little more, it shifts fine. Almost like the solenoid is sticking but the pressure makes it snap open when you drive aggressive. If I could just find someone with one of these trannies that would let me swap solenoids around, I could probably pinpoint the problem then just get that noid and it would be fixed....
Otherwise, we'll drive it until it dies then get another trans.
Project "Budget Prelude" pretty much done...
