Accord with new suspension setup
TurboFreak
Post by TurboFreak »
still needs to go lower, i can still see tire:PDT_Armataz_01_11:
Nik
Turbulent Motorsports
I have more torque than GOD!
Dark_CB7
Post by Dark_CB7 »
Before you go with a coilover, check out neuspeed's super cup kit, I have it on my 92 accord and love it, and the koni yellows are some of the best shocks you can get and have 5 height adjustment perches...I absolutely love it. You could set it to ride lower than what you have now, or higher than what you have.
Check out the function and form autolife type 2 coilovers, they're supposed to be some of the best around for accords, the reason being that most companies make springs and shocks generically for 90-97 accords. As we know, thats two different body styles, but they share extremely similar suspensions, so it works. I know autolife designed two different sets of coilovers separate from each other for the 4th and 5th gen accords though, so they are better suited to each.
That drop you have does look really good though, I think the bottoming out issue is that those agx's aren't strong enough for that spring...h&r race right?
RSXSLVR79
Post by RSXSLVR79 »
Dark_CB7;132266 wrote:Before you go with a coilover, check out neuspeed's super cup kit, I have it on my 92 accord and love it, and the koni yellows are some of the best shocks you can get and have 5 height adjustment perches...I absolutely love it. You could set it to ride lower than what you have now, or higher than what you have.
Hmm, i will have to look into those neuspeed super cup kit-i have never herd of it. THe springs that are on the car are the H&R SPORT springs. They are supposed to give a 1.75 drop in the front, but it seems a bit more than that.
I wish i would have gotten some koni yellows, but they were a bit out of budget for what i had for this car.
Function and Form coilovers.....yea im not that baller to get a set of those!
01 S2000 (Stock...for now)
Dark_CB7
Post by Dark_CB7 »
RSXSLVR79;132353 wrote:Hmm, i will have to look into those neuspeed super cup kit-i have never herd of it. THe springs that are on the car are the H&R SPORT springs. They are supposed to give a 1.75 drop in the front, but it seems a bit more than that.
lol yeah I hear ya man...well the super cup kit is neuspeed race springs and koni yellow shocks, with 5 adjustable height perches specially for neuspeed(normal koni yellows just have 3) the kit is 600, and its worth every penny.
RSXSLVR79
Post by RSXSLVR79 »
I think im going to go for some Ground Control Coilovers to remedy this sagging front end problem. Once i get all the H22 parts i need, then i can get these.
sloaccord20
Post by sloaccord20 »
looks good
i have the same struts but i have a cheap adjustable coilover kit on mine and it works fine. rides good too. mine seats a little higher than yours
