What did you improve on your car this week?
Devilchrono
traded in one car for a new car
local asshole (apparently)
2012 GTI
2002 Corvette Sold
2003 Grand Am Sold
2012 GTI
2002 Corvette Sold
2003 Grand Am Sold
v-tecivic
changed the oil, new O2 sensor, dyno'd the car, then went to gateway to get some runs in. new best time 13.1@112mph
97 civic ex turbo
13.1@112
Sparky65
HIDSSSSSS :partydance:
Also replaced trans axle seals and master/slave cylinder on a 97 Eclipse GST. Just did the clutch last week. Its got a lot of oil buildup in the intake though..
- 1993 Honda Prelude Si
Fixed the timing.
Thank you rickles for letting me occupy your driveway while doing this.
Pulled front bumper off of the 740 so I could get the auxiliary cooling fan off. Pulled it off and verified DOA. Ordered a new one so the AC no longer gets pissed when standing at idle for extended periods of time.
Cman46290
Put new front shocks and the passanger side upper control arm in yesterday. No more BOUNCING down the road.
1997 Acura Integra GSR
Intake
Header
OBX Exhaust
Rota Boost Wheels
ALL MAINTENANCE
Intake
Header
OBX Exhaust
Rota Boost Wheels
ALL MAINTENANCE
delslo
Reseated the shift boot and tightened the parking brake on the del.
Installed Check Control Module in the wagon to see what all warnings came up. Showed front fogs (duh, they were broken and just put new ones in; don't yet have bulbs in there), rear license light (removed, going to Oreilly to get another), Low washer fluid (filled up the resivoirs so fixed), and tranmission program due to the car having a 6 speed in it instead of an auto now. Figured out how to make the car know it has a manual trans in it and now the trans prog warning is gone along with the engaged E.
Talked to Courtney at Metric Mechanic about getting some better rear end gears. Looks like we'll be putting some 3.73's or 4.10's in now. Said it will make it way more fun to drive. Looks like if I keep this up I may be keeping this thing... For a while anyway...
Edison Carasio
Washed two out of three.
Does that count?
Does that count?
twkdcd595
My Accord runs again, not well but working on that... at least enough to idle it to check for leaks and flush the cooling system before it goes on the trailer ride to Texas.
