what ecu is this?
Drowzysleeper
what ecu is this?
Post by Drowzysleeper »
if you got an integra block. the only way you would have a crx head is if it was a jdm b16 head? is it dual or single overhead cam?
IM AN EPIC FAIL
J8k'S CRX
what ecu is this?
Post by J8k'S CRX »
it's a dohc. :wtf2:
:stick:
what ecu is this?
Post by Gunmetal Si »
what bottom end is it? what is the code on the head?
JesSi
what ecu is this?
Post by JesSi »
J8k'S CRX;60533 wrote:then my car is all screwie. have an jdm integra block, integra tranny, crx head (i think) and a crx ecu.
How did you come to these conclusions?
JZO6ETR
what ecu is this?
Post by JZO6ETR »
sounds like a b18c or ls vtec.with a pr3 ,.....so whats the problem??
Bitch I Might Be!
88 RX7 TII "Roatary Terror":PDT_Armataz_01_12:
what ecu is this?
Post by 90CivicEx »
JZO6ETR;60632 wrote:sounds like a b18c or ls vtec.with a pr3 ,.....so whats the problem??
If it's LS/Vtec then you need a LS/Vtec tune to pull the power out, that would be possibly why you only ran a 14.9 or whatever at the track.
You might possibly be running like Allex and if so then your cars potential is hidden from not having the right pistons in the block...That's if you are running a b18 block with a b16 head cause your power drops off at like 7200rpm's instead of 7900rpm's.
Post your heads part number, your blocks part number, your tranny number as well and we will see what problem is happening.
what ecu is this?
Post up the casting number of your head and your engine code on the block and This will help us see what you have. The PR3 is the SiR ecu(in OBD0) form. That would be the b16a. Also keep in mind the PR3 is chippable, so it could have a tune on it.
what ecu is this?
Post by 90CivicEx »
btlfedgolf;60645 wrote:Post up the casting number of your head and your engine code on the block and This will help us see what you have. The PR3 is the SiR ecu(in OBD0) form. That would be the b16a. Also keep in mind the PR3 is chippable, so it could have a tune on it.
I have LS/Vtec tunes and plenty of good b16a tunes here if chipped.
J8k'S CRX
what ecu is this?
Post by J8k'S CRX »
it's a b16a.
block #-1405440 ( i read that all the b16's that start with 1****** were from integras could be wrong though )
head #-PR3-1 Hm
tranny#-YS1
:stick:
what ecu is this?
Post by 90CivicEx »
J8k'S CRX;60677 wrote:it's a b16a.
head #-PR3-1 Hm
tranny#-YS1
So it's a obd-0 block with a obd-1 head? I do beleive the obd-0 came with just PR3 stamped on it and the obd-1 Came with PR3-1 or PR3-2 depending on if the head came off a B16a1 or B16a2.
