need help finding out whats wrong with my p.o.s.
Post by rickles8099 »
crimsoncivic;291976 wrote:Just put a new TB gasket in and its not dying anymore still having trouble getting it to idle a 900 but its at 1k so it'll work for now ..still gotta diagnose my trans problem
why do you suspect the input shaft bearing to be bad? was the transmission making the noise before you swapped in the clutch/flywheel?
crimsoncivic
Post by crimsoncivic »
Everytime I press the clutch pedal it goes away and when I let it out it comes back and this is a newer trans which really makes me mad but it may also be the pilot shaft bearing I'm not sure
crimsoncivic
Also to answer your question no it wasn't making that noise just a loud ass squeak which ended up being my throw out bearing now it still bogs down when I turn the wheel or ingage the clutch while its sitting still so if after I change my 02 sensor after cat and put in a knock sensor if its still bogging down I'm gana change my power steering pump ..after I loosen the belt a little just to make sure its not to tight and that be the issue
delslo
Post by delslo »
In my experience, many cars bog a little when you turn the wheel while sitting still/ idling. You're asking the power steering pump to do work, while running at very low RPM.
crimsoncivic
delslo;293088 wrote:In my experience, many cars bog a little when you turn the wheel while sitting still/ idling. You're asking the power steering pump to do work, while running at very low RPM.
yeah i can see that buy when i push the clutch in?
and its idling at 500? gana clean the iacv today and any other sensors
crimsoncivic
Found out my iacv little rubber 8 shapped gasket wasn't inbetween it and my intake soo put it in...idle problem is GONE!
Imagea work in progress
