do you have a grinder?
Since you are doing shocks, just grind off bothe ends down to the shock fork, then use a punch to knock it out.
Immovable Bolt. HELP
Clayton
i can do it pm me if you want it donebemberg2;191336 wrote:i've tried everything besides cutting it out. anyone have any good shops where i could get this done? or is someone willing to cut it out for a case or cold ones?
95EJ1
i dremmeled off the bolt where it runs through the lca then went to a hardwrae store and ran a bolt all the way through with a lock washer and bolt
J.M.P
Yup, same thing happened to me on my teg. I just ended up saying screw it and getting new LCA's, the bolt in mine was super stuck, got the strut off, but the lca was still screwed.
-2010 Honda Fit
-2000 EBP Civic SI
