Please help!!! 2000 type r no start!!!
juniorgarcia
Post by juniorgarcia »
JustRob;294102 wrote:Have you pulled codes to see why the MIL is on?
There are 2 plugs under dash and I wasn't sure witch one it was. So I jumpered them both, and didn't get any codes at all. Just a solid cel. I'm starting to think my wiring harness is just messed up. I have not been able to find anyone online that has had low or no volts on the k test, and not fix it by replacing the Ecu. Once again, all I can think of is wiring harness at this point. I'm so lost.
juniorgarcia
I just realized I out this on Ecu tech... Should I have put this on just the Acura Honda tech?? I figured this would be ok since it's Ecu related... Except I think this is more of a tuning section. Sorry guys
Focke
Post by Focke »
juniorgarcia;294091 wrote:It's obd2 motor, I used the original harness that was on the motor, original harness for the car, just ran vtec wires. Here's the thing though, the car has ran just fine for a very long time. And now this happened out of no where, so I doubt I have the wrong year Ecu, or I have the wrong harness because I've been driving the car just fine. But I'm using an obd1 p28 Ecu tuned on chrome. As far as re setting the cel, I've removed the Ecu fuse and left it out for a few minutes, then plugged it back in and nothing. I'm so frustrated!!! Thanks guys for the replies please keep them coming!
Wait.......youre using the harness on the motor and it is a JDM motor in a US car?
