So you can get 81.5mm OEM head gaskets?portenio78;291510 wrote:you'll be fine with a stock OEM gasket. I too am 81.5 and 700whp no problem.
Cometic Head Gaskets?
eh2_Erik
Now s13_Erik
The OE head gasket should already at 81.5 mm. I will measure when I get home to be sure.eh2_Erik;291523 wrote:So you can get 81.5mm OEM head gaskets?
eh2_Erik
Oh really? I was unaware of this lol. I guess i'll measure the one i have at work too.Waffles;291525 wrote:The OE head gasket should already at 81.5 mm. I will measure when I get home to be sure.
If thats the case, would it be ok to use or would i need an 82mm one?
Now s13_Erik
bks
You can use a stock 81mm gasket on 81.5, wont cause any problems. I think thats what portenio was getting at.
On my first LSV I used a cometic. I leaked oil around the entire engine. Could have been because the block wasnt square, the head wasnt straight, who knows. I ended up putting on a felpro and had zero issues, lol. Same engine, everything remained the same aside from the gasket.
eh2_Erik
I've been reading more, everyone says stock head gaskets are good for overbored cylinders. Some say they're good for up to 82mm or even 83mm. I think
I should be ok for 81.5mm.
Thanks for the feedback, I would've never searched if the stock gasket would even fit.
Now s13_Erik
eh2_Erik
I read that they're usually 81.75mm so that sounds about right.Waffles;291615 wrote:I just measured the 3 I have here and they are all just a hair over 81.5 mm
Now s13_Erik
