i have used this method before lolymisoqt;292050 wrote:damn ^
I've never had luck getting a crank pulley off with air. Twice I had a compressor brought to my house to use and ended up getting it with a "breaker bar" aka the handle off of my jack over a socket wrench and a screwdriver in the flywheel to hold the motor from turning.
Crank pulley bolt
Crank pulley bolt
Racecore.com
Racecore.com
Crank pulley bolt
ive broken breaker bars before.... just ask getteg about his integra and how i took his off and how long it took me.ymisoqt;292050 wrote:damn ^
Edison Carasio
Crank pulley bolt
With my Civic we hit it with torch, penetrating lube, electric impacts, air impacts and everything and had to use the massive gun eventually.rickles8099;292064 wrote:ive broken breaker bars before.... just ask getteg about his integra and how i took his off and how long it took me.
luvmyhondas
Crank pulley bolt
torch is your friend here... and a STRONG impact.
AKA audioguru76
The faster I go, the broker I get!
79 Hondas and counting!
