whats this?
sirricealot
whats this?
Post by sirricealot »
Does it effect compression n such? Vacuum?
2006 Chevy Cobalt SS/NA 2.4L IL: FEERME7
2010 Kawasaki Ninja 250r IL: RUNYON
xbxlive: sirricealot07
ps3: sirricealot7
David Runyon
whats this?
Post by Phate »
sirricealot;265757 wrote:Does it effect compression n such? Vacuum?
I don't know. Heres a how to on how to replace that shit though.
http://www.team-integra.net/forum/blogs ... ement.html
whats this?
sirricealot;265737 wrote:Yeah p30 clearly on plug. Does leak a little, can't find anywhere what's supposed to b there. Figured might b culprit of idle issues too
No, it has nothing to do with your idle issue. We tired helping you fix that. You were too lazy to do it the right way. Until you do it properly, you will continue to have issues.
No. It has nothing to do with either.
Go to Acura and buy a new end seal (Part Number: 12513-P30-000) and a tube of Hondabond. They cost next to nothing and are usually stocked. It's not be a bad idea to replace the valve cover gasket set while everything it apart too. Follow the DIY previously posted.
Redline
whats this?
Post by Redline »
I love hondabond when I was driving home my heat core inlet tube busted. all I had was hondabond with me. I put it on the core and shoved the pipe againest it and never leaked again. even put it on the hose and held the hose on with out a clamp
More power coming soon
sirricealot
whats this?
I'll just get one online.also the idle issue I had done what u said but still messed up. Was told timing may be off. Is there a thread on timing adjustment?
ps3: sirricealot7
David Runyon
whats this?
sirricealot;265772 wrote:I'll just get one online.also the idle issue I had done what u said but still messed up. Was told timing may be off. Is there a thread on timing adjustment?
No, you did not. I know this because in the last video you posted, the vehicle was not at operating temperature. The SM excerpt specifically states the vehicle needs to be at operating temperature.
91beatuphatch
whats this?
Post by 91beatuphatch »
Redline
whats this?
Post by Redline »
sirricealot
whats this?
thanks guys.
ill check it all out when i get a chance.
maybe ill work on it on my day off, idk. i just need to get it sold.
if i could get a few hundred more than i owe i'd be game. i at least wanna get 10% back of what i put into it lol.
ps3: sirricealot7
David Runyon
91beatuphatch
whats this?
thatll never happen with a DA. like i told you before i have a like $500 cat back on my car. thats 1/4 whats its worth. good luck though... and let me know if you need some help im a short drive from you.
