Immediate problem, hoping for Immediate Solution...
did your lights get really dim and stuff while you were driving like the battery was almost dead? mine was doing that, the battery was draining while i drove around. i ran a new wire from the alt to the battery and it fixed it. you might give that a shot if your running out of ideas
Racecore.com
Racecore.com
Jawsiiv
Replace fuel filter, and put in several ECUs, checked fuses, all good. Only thing left is the injectors, but i thought you had to have a CEL light that indicated if the injectors are bad?????
Also a couple of times the car backfired/ mini popped. Is it possible to have a clogged exhaust that has backed up?
boxbodyblazer
check timing?
Jawsiiv
Naw, because thats the last thing I wanna check since I gotta pop that Pulley off just to see if the bottom is matching the top. If my timing if off I would be pissed. Why would my timing be off, after its been on 6 months of highway driving when it was put on in January correctly????
Timing gun?Jawsiiv;188115 wrote:Naw, because thats the last thing I wanna check since I gotta pop that Pulley off just to see if the bottom is matching the top. If my timing if off I would be pissed. Why would my timing be off, after its been on 6 months of highway driving when it was put on in January correctly????
Jawsiiv
Could the timing be off and the pistons not hit the valves? Also on the Crank Pulley there are 3 lines then a seperate line. Where does it have to be in relation to the camgear to find TDC?? I know on the lower cam cover there is a mark to show where the Cam pulley line should be, but I don't know which pulley line should be aligned there. The engine is a Z6 head with B7 Block.
Also, no one around Belleville is renting a time gun, and when I checked all 3 Auto places, Oreillys, Autozone, and Advance Auto, its like around 40 bucks.
Update, All Fuses checked, fuel pump primes, spark on all the plugs, no bad CEL, fuel in the chamber(old plugs right when I took them out smelled like gas) One thing though is that when my brother checked the the spark on Cylinder 3 white smoke came out the spark hole.
boxbodyblazer
timing can jump on the harmonic ballancer there is a mark to line up with the timing cover then once you line that up the top should be lined up.
Jawsiiv
On the pulley though, there are like 4 lines. Three together and then on separate. Is it the line in the middle that should be facing up.
Ughhhh Off with the Crank Pulley........ Sauce Nuggets....taking a break now but will be back at it around 1:30. Noodle Break.
boxbodyblazer
Just take the harmonic ballancer off and the lower timing cover as i cant remember off the top of my head it only takes a few minutes to make sure everything is exactly right.
Jawsiiv
I set the cam to TDC.....Pulley notchings are about at 10 oclock from where they need to be which is at the arrow on the lower belt cover... Problem????
