you can put 450's in your car if you chip your ecu and tell your ecu that you are running 450cc injectors. that will shorten the length of your duty cycle pulse for the injectors and not run it rich.
how to check fuel pressure:
http://media.honda.co.uk/car/owner/medi ... /11-80.pdf
how do you know your current fuel injectors are not just dirty, your fuel pump is going bad, your fuel filter is dirty, or you have just contamaniated fuel?
Possible Injectors for 93 civic
Jawsiiv
I know when the fuel pump is not on cause it will not prime when I turn the key, but how do I know if it is going bad?????rickles8099;126260 wrote:
Early June, I did the unforgivable....I put shell gas in my car. That is when ti started. I changed the Filter and bam......still occured. Changed the O2....bam still happening....
Even after emptying the tank and putting various types of trusted fuel Amoco, Mobil etc.....still having problems...
Then one day it stopped.....no sputtering no low idle, no loss of power....it was good for like 2 weeks, I put some Lucas fuel cleaner in there and it was okay...then like last week it just started over again.
When the Sputtering and the CEL comes on, I turn off the car and it resets. Sometimes it comes back before I stop the car, sometimes it does not.
Thanks for all the help people cause it sucks when you trying to roll on the highway, and you lose power and it begins to stutter.
and what is the CEL saying?????
its not your pump or injectors.
dont ever put that "shit" in your gas tank. i dont care what it is. just wasting your money.
Jawsiiv
Thrown 43.mike93hatch;126266 wrote:and what is the CEL saying?????
Car will run find, then randomly CEL turns on and sputter/loss of power. Turn off the car, it resets.
Never know when it will happen or if it will happen, but whenever jump the car it says CEL 43.
