car sputteres at 5,000 and has no throttle response
Drowzysleeper
Post by Drowzysleeper »
b18a
IM AN EPIC FAIL
tommygun89hb
Post by tommygun89hb »
is it throwing any codes here are my guesses
fast idle valve on your t/b
tps sensor is placed wrong
Drowzysleeper
no cels and the plugs are way lean white as a ghost .
IM AN EPIC FAIL
Post by Phate »
I vote timing.
Drowzysleeper
trying to get my car to cut out at 5000, i think its actually a rev limiter. i ecu is stock and the motor is an ls, idk what the hell.
IM AN EPIC FAIL
Post by Gunmetal Si »
plugs are white-as in new looking white? what ecu is it?
Drowzysleeper
plugs were white as in lean as fuk, and its a stock p75, maybe my dizzy? also my tak could be way wrong
IM AN EPIC FAIL
Drowzysleeper
ok dizzy is fine, tak is not right, installed an autozone tac and it was also wrong. i guess my timing is fucked.... with me hitting a rev limiter at 4500ish if i was in limp mode i would b throwing a cel?
IM AN EPIC FAIL
Drowzysleeper
ok so my rpms are actually rapping out just the tac is wrong also the car will not idle when warm you can be stopped and it will die if you dont press on gas and if you press the clutch in while moving it will die anymore help would be great
IM AN EPIC FAIL
