Turbo cost?
Turbo cost?
Post by rickles8099 »
quick rundown list:
1)get a good internally wastegated turbo, either used or new brand name, doesnt matter. just make sure its in good shape. (biggest key factor in the whole turbo setup.)
2)hf manifold
3)hf-whatever type turbo you go adapter plate and down pipe flange
4)oil lines
5)450cc dsm injectors and injector clips
6)any cheap new/used intercooler (can get for well under $200)
7)chargepiping (chopped up cold air intakes, exhaust piping, big radiator hoses off of trucks, they all work)
8)boost gauge and oil pressure gauge
9)obd2 to obd1 conversion harness
10)chipped p28 equvilant ecu (either straight p28 or p05, p06 converted to p28)
11)coolant lines for the turbo if the turbo is oil and water cooled
12)self fabricated downpipe
and then install it all yourself. all of these can be had for anywhere from a couple hundred dollars (if you have the hook up on parts or wait long enough for deals) to over a grand. numbers 6 and 7 can be had for about $200 if you go with knockoff names and search ebay.
twistedimage
Turbo cost?
Post by twistedimage »
The TDO4H-19T greddy kit is the one i think im going to get. Is there anything else i need that the kit doesn't include? I see there isnt a bov or a intercooler.
