bildo16;14817 wrote:most vehicles that we have come in the shop w/ a no start condition that are actually caused by a fuel pump, you can get a hammer, or anything to tap on the fuel tank with, and the vehicle will start and run with no problem. on some occsions, the vehicle will actually start a few times in a row, then if you let it sit, will not start again. before you change the fuel filter, disconnect the supply line to it and have someone crank the vehicle. if no fuel comes out, then your pump is bad. if fuel starts coming out, then work your way from there forward- fuel filter, plugs, bad gas, etc..
+1 i have had that problem in my old hachies
