to wrap or not?
remoer
to wrap or not?
Post by remoer »
99RedCivic;43903 wrote:you could always get it coated. I've always been told not to wrap it because of trapping moisture, especially if it's a daily driver.
there is statement is true on both a counts but not completly true on the second. ceramic coating is reall good. wrapping is to keep the engine bay temp dowm. yes it does traps moisture if not done correctly, and if you have shitty hearder this will also make them crack or even break. here's some proof wrapping yout header.
transzex;694778 wrote:The header was wrapped before install.......after about SIX years the firberglass (DEI) started falling apart. First at the collector, then on the primarys......
when I removed all the wrap......no rust......
I have/had other pics, but might have lost them in a HD crash, they might be backed up on my other puter which has been in storage since Feb......
remoer
to wrap or not?
Post by remoer »
here's better pics of bones header. where you see the rust it's where he didn't wrap.
transzex;893860 wrote:You can see where I didn't wrap, and where I used it as a skid plate :)
it's trust and characater is what i need around me, who you choose to be around you let's you know who you are. and one car in exchange 4 knowing what's a man's made of, that a price i can live with. - Hans
1 monkey power = 0.332 hp.
22mm>14mm, This means a 22mm sway bar is roughly six times stiffer then the 14mm sway bar.
actually how much stiffer the bar is? 510% stiffer.
ek20-hatch
to wrap or not?
Post by ek20-hatch »
Yes I would wrap it.Less engine temp.
zooyork22
to wrap or not?
Post by zooyork22 »
Deffently do not wrap it. If moisture gets to it, it WILL crack. I would perfer hot coating. Jet Hot does a great job. I just had it done on my dad's WRX and it will be cooler than if you wrapped it and the durability is much stronger.
- "I like my honda like I like my women, D's instead of B's"
remoer
to wrap or not?
Post by remoer »
zooyork22;48884 wrote:Deffently do not wrap it. If moisture gets to it, it WILL crack. I would perfer hot coating. Jet Hot does a great job. I just had it done on my dad's WRX and it will be cooler than if you wrapped it and the durability is much stronger.
yeah but not everyone can afford it. since your dad did why haven't you?
zooyork22
to wrap or not?
Post by zooyork22 »
Why the Hell would I hot coat my stock D16 header when I will be going turbo with in a year??:whip2:
to wrap or not?
Post by bildo16 »
zooyork22;49551 wrote:Why the Hell would I hot coat my stock D16 header when I will be going turbo with in a year??:whip2:
cause all the cool kids are doin it!
granturismonut
to wrap or not?
Post by granturismonut »
wrap it
J8k'S CRX
to wrap or not?
Post by J8k'S CRX »
i made my mind up a long time ago.
:stick:
tommygun89hb
to wrap or not?
Post by tommygun89hb »
i have a 89 civic and i didnt wrap my header and i decited to do a test of under hood test so i disconnected my fan and sat my car in the drive way and let it idle for about 15 min and checked the temp gauge and i didnt really notice a diff to tell you the truth i just think it personal pref to be honest
