Makes the engine back look a ton better, its not so plain adding some sorta color to it.
Good job.
Painted my valve cover today still under construction
Silver Knight
Even though red is played out, that looks Hawt.
d16ej1
g3integragsr;49155 wrote:What paint did you use? Where did you
get it? Im getting ready to paint my valve cover and I really like that paint.
Jar Jar Binks
looks good!
g3integragsr
Did you clearcoat it or just paint it? Does anyone know if it's better to use the Krylon Wrinkle Finish or the VHT Wrinkle Finish?
Looks great man. The red is common but you did a great job sparying it. Rep 4 U!
slow del sol
Looks really good for rattle can!
How did you prep the metal?
d16ej1
I scuffed it with a scotch brite pad then ran it threw our parts washer at work then sprayed a coat or two of etching primer and thats about it on the prep workslow del sol;49234 wrote:Looks really good for rattle can!
99SilverCX
did you buff the letters out after you painted it?
