In total with with snout rebuild, rotor bearings replaces, and to recoat the rotors was $500. But I know have a brand new SC now that should last 100,000 miles.crazysol;118839 wrote:How much was the supercharger rebuild. Do the jrsc's max out at around 12psi
Yes the d series SC kit is good till 11-12 because after that the heat from the SC starts decreasing your power. Most say 11 is the highest you should take it. i'm happy with 10.
Im hoping to do a little run against Dale to see if I can at least keep up with him now.
